Wie findet ihr das, das die Alfa V6 Motoren gestoppt werden und Opel Motoren eingebaut werden????????
(Quelle: http://www.Italiaspeed.com)
Although it has become clear that certain variants of the Alfa 156 replacement are to be fitted with GM-sourced engines, Alfa Romeo engineers insist that the potent nature of the Alfa Romeo 157 will not be diluted, but rather it will be enhanced.
Paolo Massai, vice president of the Alfa Romeo engineering development centre, is a passionate man when it comes to his job.
When questioned on the implications of the new GM V6 destined for future Alfa models, Massai made it clear that the engine will still be mainly Alfa designed, referring to the GM block as an “insensitive and inanimate piece of metal".![]()
The pistons, cylinder liners, combustion chambers, manifolds, injection system and electronics are just a few examples of what will be Alfa Romeo designed. Massai also mentioned that the Alfa engineering team had been hard at work replicating the traditional Alfa V6 engine sound, and light-heartedly declared that he would quit his job if they didn't achieve it!![]()
